someone should try it
Matt
Minnesota
I like the look of that turbo over there. Is there going to be ample room to drop a downpipe, or is it pretty tight?
jdgleason
Fort Collins, CO
I would try to figure somethin out from the 2nd alternator spot too. Goin from the body would make pullin the cab that make tougher.
Charles
You can't go from the body/frame unless you use solid motor mounts or some seriously expensive flex joints in the exhaust. One charger must move in unison with the other or you'll have some big plumbing issues.
Dzchey21
wyoming
Ample room... no enough room... yea. I had to bend the inner fender bracket out of the way but there is room.to drop a 4 inch downpipe between the cab and frame
Nos_GTSR
Rexburg, ID
I thinking its going to have to be supported by the 2nd alt bracket. Ill get some pics of what I got cut out of card board.
Dzchey21
wyoming
That's the only place I saw as well. Keep in mind if you want dual fuelers u may need to modify the bracket that's why I have been waiting on my bracket. Can't do much till I know where it goes
Dzchey21
wyoming
Looks like my bbracket is going to work decent with the Turbo mount just gotta get it mounted and see what kind of room under the pump I have to make a bracket going to try and get something mounted and started on tomorrow
Nos_GTSR
Rexburg, ID
I think Ive got it figured out I just need to figure out some way to suspend the turbo where I want it and it doesnt help that the truck is an extra 2 feet off the ground being on the trailer.
Powerstroke Cowboy
Montana
I have a Quick Question for you 6.4L guys..
What are the specs on the compressor wheels on the stock turbos>> Inducers and exducers???
Thanks!!
PS. Dustin I have spell check now.. I figured out how to download it of the web. Thanks for trying to help me though!!!
Dzchey21
wyoming
Thanks!!
Cool glad you got it..
Someone correct me if I'm wrong but the inducers are aall I know and I think they are 65/53
Dzchey21
wyoming
I'm thinking a cherry picker or taking the hood off and using an over head hoist that's my next step too
Nos_GTSR
Rexburg, ID
Hot pipe is coming along nicely. I just need to get the mount made and get the turbo suspended.
Nos_GTSR
Rexburg, ID
Im stuck trying to figure how to mount it and where to get oil and where to drain it. One the gates will be here tomorrow or thurs so then that fun begins. BTW Thanks Jacob.
Matt
Minnesota
Why not pop the exhaust housing off and build your mount to it, would be quite a bit less weight to hold there. You probably thought of it, but suggestions never hurt. Haha. What are you planning to do with the oil fill neck? I believe Dustin is going to just use the factory oil feed location, but I suppose it may be a bit more of a challenge beings you're still running the factory turbos as well. I really can't wait to see that big bastard hanging out there. How much room is there for an air filter?
