AKHILF
Whats your guy's thought on mounting some 6.5's in the door of our crew cabs? I have a huge box behind me seat and the rear speakers are pretty close to it so i figure putting upgraded speakers in that location would be a waste.
Just put these in. Now I can turn up the highs alot more. Not near the distortion the stockers had.
My box is behind the rear seat and the seats moved forward around 3 inches. Its a huge box haha each L7 12 has 1 cubic foot. And the zx2500.1 takes up 3/4's under my seat and my component amp takes the rest. And yeah man I will for ever be a believer on dynomat. The only thing not covered in my truck is under the front seats. I did the whole back wall and covered the vents and to the front seats. I did the whole roof and that was a pain but well worth it. Pulled all the pillar covers off and did behind them. And one of the most important things is on the doors. Cover as much as possible on the outer door skin. Stick your hands through all the holes. I got everything but it took a bit of doing. And make sure you have a patch behind the speaker on the skin for sure. Then I covered the whole inner door panel and cut the tabs for the door panel and laid them over on them selfs. I cant believe how much it helped me. Even just closing the doors you can tell its solid. Oh and i have the fuel gauge and compass up on the roof and that use to rattle the worst. I put as much dynomat on the inner and outer piece for that as i could with it still fitting on and it wont rattle anymore. If you buy two of the bulk packs that are 36 sq ft you will use almost all of it. Good luck and take your time.
Pop the door panels off and cover those big holes Gare...it'll get even better.
2 hour job at most after a trip to the hardware store.
I hope there's a baffle behind those to mount them solid to the door, not just the door panel?
If not...you really need to add one and screw it all solid to together.
A speaker just mounted to the door panel cannot possibly play right...the cone movement will just make everything vibrate, if you want solid midbass it needs to be mounted solid.
