psduser1
Alright, I've got an srp1.1 on my pickup, and overall I'm satisfied. I've put about 500+/- on it, some hammer to the floor, mostly easy driving. It carries 3200ish on my big tune (140 from pho), low duty cycle, maybe 35-40%. It's all good except...
Twice now, I've lost hpo, as in all of it. Dead in the water. Both times the engine was at full operating temp, 205-210 on the scangauge. I let it set for a while, 1/2 hr maybe, and then, after 5-8 cranks shed fire off, run like a dream again.
Couple of times under normal use ( not running the snot out of it), the engine would " hiccup", then smooth right out, not actually die. WTF??
The icp sensor is dry, less than 5000 mi, ipr has less than 1000 mi also dry. I cant see any bad wires, or anything else obvious, and this problem has only started since i installed this pump.
I havent talked to stealth yet, that'll be tomorrow, or whenever i can get ahold of someone there. Honestly I'm not sure its the pump, thats just the most obvious thing I can see. I've had extended cranks when the engine is hot, but i had that even when i was using the adrenaline, so I'm not sure that's related???
Any thoughts, opinions, advice would be a big help.:wtf:
