Stay of execution.
brewer
Good to see you decided to keep it Joe. Looking forward to the progress :toast:.
JoeDaddy
Gridley Ks
Started my Pyro probe mount at 7:30 am this morning, and was done, cleaned up, sitting here, drinking coffee again at 8:15 am.
I put this off for 3 years because I thought it would be complicated! :fustrate:
Headed to town for some sawzall blades to chop the pancake and install my 3 year old brand new but starting to rust DP that I never had time for.
Every time I finish another regular maintainance project on this truck now I wish someone would just PUNCH ME IN THE FACE! :doh: Damn you procrastonation!!!!!!
JoeDaddy
Gridley Ks
Austin, Tx
JoeDaddy
Gridley Ks
Got distracted by change in career and another project which will be sold to finance the resurrection of this one.
Hoping to start the D60 install this weekend.
JoeDaddy
Gridley Ks
Finally got the donor disected, had about an hour this evening to burn some junk together so y'all could see how this is going to go.
http://sphotos-a.xx.fbcdn.net/hphotos-prn1/s480x480/525738_367085346715483_1988765369_n.jpg
http://sphotos-a.xx.fbcdn.net/hphotos-snc6/s480x480/269543_367085693382115_69456250_n.jpg
http://sphotos-b.xx.fbcdn.net/hphotos-snc7/s480x480/407703_367086003382084_1779540363_n.jpg
The green colored tube is to be secured to the axle via a 1/2 piece of pipe. Then the coil pedestal will get bolted to the top of the green tube. The shock mount will be cut off and welded to the new radius arm. The RA mount will be moved down the frame and the radius arms will be about 4' long.
JoeDaddy
Gridley Ks
Got the rest of the mock-up done.
http://sphotos-a.xx.fbcdn.net/hphotos-ash3/s480x480/561886_367522596671758_1180137050_n.jpg
http://sphotos-a.xx.fbcdn.net/hphotos-prn1/s480x480/526048_367522320005119_1184528747_n.jpg
The springs can be mounted with or without the base cup and still be used with the anti-sway bar. This will reslult in the same lift the F350 had stock with cup. If I get time tomorrow after work I'll finish weld everything and get it ready for paint. When that's done I'll be ready to get the front end yanked out of the 2wd and do the swap in a day hopefully.
JoeDaddy
Gridley Ks
Hotrodtractor
Mingo, Ohio
If you are still going to go the radius arm route you need to change your design a little bit..... you need some sort of bushing for flex at the axle end.... otherwise you've just built yourself a very rigid swing arm at the front of your truck.... I assume you know this, but others might not.
