Stay of execution.
JoeDaddy
Gridley Ks
If you are still going to go the radius arm route you need to change your design a little bit..... you need some sort of bushing for flex at the axle end.... otherwise you've just built yourself a very rigid swing arm at the front of your truck.... I assume you know this, but others might not.
Right. That's part of the reason for swapping the entire chassis to a 4wd instead of a 2wd conversion. The length of the swing arms would allowed plenty of rotation but like I said in the last post....no need to reinvent the wheel.
On edit: Plenty of rotation meaning for hauling on hwy with some field work. 6" of articulation being plenty.
Cat_rebel
Rebecca Black took my seat
Good job Joe, glad to see it moving right along.
If I might make a suggestion, I would have cut that frame in a Z & then rewelded it.
Something like this-
JoeDaddy
Gridley Ks
are you going to fish plate it? looks good
do you have your flame suit on? :)
Yup and it will go down the road with a 20,000 lb gooseneck just like it is :D
Its sort of a rub Cat. Strength is for the most part reliant upon the Fitter and not the fit.
duke1n
You have that case of beer you owe me? Is JoeDaddy a welsh that is not to be trusted to pay off his bets?
duke1n
Maybe I wasn't clear? Maybe you struggle with reading comprehension? Whatever it is are you going to put some money behind that mouth Dorthy?
A beer is enough, throwing C-notes around doesn't make my best guess any more accurate than your's. :toast:
Sounds like a bet to me? I figured people on this forum that made bets would stand behind their word and pay them off. Am I wrong?
Here's the thread and JoeDaddy making the wager. Are you going to say this was not a bet?
http://powerstrokearmy.com/forums/showthread.php?t=14857&page=5
JoeDaddy
Gridley Ks
JoeDaddy
Gridley Ks
It's been well over a year mow pulling heavy loads both GN and BP. I think it's safe to say it's tested.
A lot has changed recently, I now have 2 SD's to do the pulling. The OBS is about to go to pasture. I can't convince myself to sell it and it's only worth anything to me. So that leaves 2 choices. Restore it or Race it. :D
I'm currently sitting on 5 sets of spare injectors and HPOP's so I should be able to secure a good set of injectors and pump. Turbo would have to stay stock for now. Maybe this time next year I can find a BTS and go balls out!
bluedge8
Champlin MN
Your alive LOL
I was looking for an sd for side work duty but couldn't justify the cost. Ended up buying a 2001 gmc Yukon xl with a 5.3,,, Still have my '96 though
JoeDaddy
Gridley Ks
Decisions.....Decisions.......
300/200's or a more pedestrian 250/100?
Either way I'm going to need a tranny and turbo(s).
