Streetmax-x turbo advantages over stock 2017 turbo
harrelljr99
I have a 2017 f250 ******d running 0-200 Tyrant tunes.
I noticed Tyrant has a tune profile for street max-x 0-225 tune
If I were to go with that in place of my stock 2017 turbo is there anything else I would need to upgrade such as.
- Dual fueler with lpfp cp3
I currently have
- no limit cold air intake
- H&S intercooler pipe upgrade
- 5” exhaust
- running Tyrants AWESOME tunes!
Six_Sloww
Southeast MI
You can drop it in and pick up power without any additional modifications, or you can pick up even more power with an upgraded cp4 or dual pumps.
Six_Sloww
Southeast MI
I forget what stock fuel 2015+ make. It'll be a solid 40+hp bump I'm sure but that 66mm is probably good for up to 80 hp over stock with more fuel. Depends on what that stock turbine will flow.
Six_Sloww
Southeast MI
Np. I'm just going off of what I remember, plenty of vendors on here that you can call up can give you 100% solid info.
harrelljr99
Let’s hear it vendors now would be a good opportunity to show off your vast knowledge of your products carried, and strong support you’re able to provide!
harrelljr99
Is the street max x that goes on the 2017+ a vgt or sst turbo?
Six_Sloww
Southeast MI
The SST is the old garbage turbo. All aftermarket turbos are built from the non SST style turbos
harrelljr99
I currently have
- 5” exhaust
answer is no, you wouldn't need to upgrade anything else and yes there will be a small bump in power. To take full advantage of the larger turbo, a stroker hpfp or duel fuel would max it out and you would be around 650rwhp.
