Sub Box...without losing console or lockboxes?
BIGDZL
So looking to put a subwoofer into a 2015 F350...but don't want to lose the space in either the center console and definitely don't want to remove the very handy locked boxes under the rear seats. JL stealthboxes require losing one or the other. Has anyone had any luck installing a custom box behind the rear seats? I've seen several custom box options for this space on Ebay, but would like to hear first hand experiences regarding quality, install, sound, etc.
http://www.ebay.com/itm/Custom-Ford...-Enclosure-Kicker-Cvt12-System-/131456715084?
Also considering a small JL Audio wedge, but not sure if the 10", 12" or 13" versions might fit...if any at all...
http://www.ebay.com/itm/400749547163?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
The Butcher
You can get two JL 12s or 13s back behind the rear seat. I ended up sacrificing the small storage cubby under the seat on the passenger side for the two amps (subs and mid/highs). You could probably get a single amp under one of the front seats if you are only doing subs and running the factory mids/highs. Sounds excellent. Plenty of bass to fill a crew cab.
n54power
I've had great luck with moose audio. I have their box in my truck and I still have room for gear and a fire extinguisher
