suncoast trans filter
mortal798
Michigan
Here's the fluid flow description...
  • Transmission cooling description EARLY BUILD ONLY.pdf
Erikclaw
Central CA
Well how many of you actually change the cooler when rebuilding or repairing the trans? It says to replace and not to flush. When my trans first grenaded the shop chose to replace it cause of so much material in the fluid. I don't plan on replacing it this time since it was the tc and the trans had no metal found in it.
