I've had 2 different tire shops say they won't put 305 50 20 Nitto 420's on my truck because its outside the load range of the tire. I've seen SEVERAL trucks that are a lot bigger than my shorty with them on. I found a place that will do it but have any of ya'll had this issue?
The Nitto spec says they are good for 3086 lbs at 50psi.
What EXACTLY were they wanking about? The BFGs on my truck are D rated for 3195 and Discount mounted them like it was cool. That's ONLY an additional 109 lbs over what those Nittos are rated.
Maybe it's because I had a go around with the IDIOTS at Discount in Las Vegas that I don't care too much for their thinking abilities, or shall I say lack thereof. They tried to put my tires back on after a rebalance with ROCKS IN THE TREAD. Then they completely ignored my request not to play with the tire psi. The lead monkey tried the, "That's what the computer says" BS when I called him out about the psi. "Did the computer tell you to balance my tires with rocks in the tread, too?"
But then again, the Discount monkeys in Scottsdale, AZ tried to throw my 365/65 Toyos on the trash truck when I told them to put them into the back of my big red truck when I bought the 315s. :fustrate:
I worked in a tire store, and I'm telling you, you have to watch these guys LIKE A HAWK!
