6speedsd
Ok this will be sort of hard to explain so bare with me. Truck is a 05 with 5R. Every now and then it'll go into like this quick shift mode. Like it shifts before it should. Sometimes if I take off from a stop it'll shift all the way to 5th before 30 mph. 2-3 is usually where I see it the fastest. Like it won't hold in 2nd very long. 3rd shifts sort of hard too. And then at times if I get on it after it has shifted into 4th (or 5th, however you want to look at it), it will hold for a bit then shift to the last gear then OD almost Simultaneously. And what happens with the TC when it shifts into OD? Locks or unlocks? All I know is when it shifts into OD, the truck really takes off. I don't think I have a TC problem, but I'm not all that knowledgable of auto trans. Has GoGo solenoid in it as well, which I'm tempted to take out because 3-5 shift is almost too harsh.
Best I understand the 5R doesn't shift 1-5, it's 1,2,3,5,6, then OD correct? I know this description is pretty hard to follow and I apologize for that. Just can't figure out how to put it to words. I have AE and heard I can watch output speeds and such to see what's going on. But I honestly don't know what to watch, and wouldn't know what the info I got really meant!
