Mark Kovalsky
Yes it is likely. In my mind it is the most likely cause of the problem. The programming is identical for 4x4 and 4x2. The computers are the same, too. The 4x4 sends a signal when it is in low range. If the computer sees that pin grounded then it will shift the trans on the low range schedule. It doesn't know if the truck is a 4x4 or a 4x2.
