Transmission cooler lines
Mark Kovalsky
SE Florida, USA
I think my trans cooler is plugged a bit so I'm going to order the Tru Cool. The previous owner also bypassed the radiator so I will be hooking it back up. So basically I should go in to radiator then out to cooler, then back to trans? That's it? That simple?
Yes, that's it.
TARM
Yep thats the correct way. If that rad has been open then make sure to flush it out .
TrailerHauler
Michigan
Good info, I didn't see a straight answer as to what fitting size went in the bottom of a superduty radiator though. Half inch pipe thread, or inverted flare?
