ThatWhiteKidWhoStrokes
I have a 4wd trans with tcase and want to make it into a 2wd trans. I know most older transmissions you have to swap output shafts and tail housings to make it work. Which is a pain. But. Like when I order my comp unit from Midwest I didn't have to specify 2wd or 4wd which leads me to believe they are the same transmission that doesn't involve Alot of work to change around. But I can't experiment since it is my daily right now. 2014 f250 6.7
