- Joined
- Oct 3, 2012
- Messages
- 11,845
- Reaction score
- 35
have a look here. this should be all you need.
http://powerstrokearmy.com/forums/showpost.php?p=698611&postcount=42
No, it shouldn't. It can negatively affect the clutches, but not the solenoid.Mark, does tuning/changing line pressure effect the line pressure solenoid negatively?
No.Gonna order the line pressure Solenoid. Hopefully that should work. The TC doesn't go out very often on these trucks do they?
I can't think of a way that it could do that.Could the solenoid that controls line pressure also cause a feel of lost power?
Please educate me. What does an upgraded EPC solenoid do for you? How is it better?want to order an upgraded epc solenoid but not sure where to get it. im looking at mts diesel and they have a decent price on one. anywhere else i could get one. want to look at all options before i order.
Enough to fill it. Probably about 8 quarts.Seems like a simple task. I may try doing it tomorrow. How much fluid should I add back when I'm done?
You can't get it out while the connector is plugged into the wiring harness.Thanks mark for helping us.. it seems easy but that plug just won't come out... should u unbolt the plug that mounts to outside case of tranny?... just don't want to break anything
It is bad if the PCM didn't command that, it's normal if the PCM did command that. I can't see what the PCM is doing from here, that takes a high end scan tool that is looking at live data to determine what the PCM is commanding.Had the truck looked at and they said the line pressure solenoid dropped to 170 psi and spiked up to 200psi. Is that bad?
