White_monster
No, but it wouldn't hurt
Doesn't this show there's enough fuel, but a huge restriction on intake/heads etc.? Yeah you can cram more air in with turbos, but has anyone tried a different intake or ported with stock fuel and tow powers or similar? Or ported or billet heads? And yes, I understand the stock fuel would be falling off with atomization, just curious if anyone has tried it.
I just recently recieved my Tow Power X atmo setup and plan on installing in the coming weeks. My plan was to run this setup with stock fuel and down the road upgrade to the 62mm VGT from the High Power's and dual HPFPs of some sort. After reading this thread what would be the opinion on running the Max Power VGT instead of the High Power VGT? How would a 76mm/66mm compound setup preform? The factory turbo setup is 65mm/56mm right? Would keeping the the turbo sizes within 10-11mm help? I'm thinking dual fuelers 110's/85's maybe even 60's and the above mentioned turbo setup.
Factory is 65/53
Made 693hp/1258 ft lbs with stock fuel and canned H&S 300hd, with a 71 over a stock HP with a batmowheel. Also must note, threw a zf-6 manual tranny.
What dyno? Nice numbers for sure! Are they corrected??
People are running non VGT 66mm turbos with no problem right. How does a set of Max Powers preform with dual fuelers and a small/medium nozzle? My thought was if you could get the VGT to do a little more work the risk of overspeeding the atmo would be less. My knowledge on turbos on a scale of 1-10 would be like .5.
Awesome should be even nicer down here at sea level.. I think that is going to be my plan then. Precision 76mm/66mmvgt dual k16's and 30% nozzles.
if you are doing a 66hp i would do the 82 atmosphere.
