Is there much of a spool up difference between a 63mm & 66mm?
Sent from my SM-N900W8 using Tapatalk
Being realistic, a little, a little slower. But not much of a difference to be honest. Stock fuel and a 66 runs awesome.
Morgan. (MMidwestMorgan)
Have you any data log with your setup from stock to 63 or 66?
I know you show a 73hp increase over stock. Was that with a HOT hs-tune only?
I know you have posted this somewhere else. This seems like an appropriate thread to re look at this. This is a good thread for all you turbo builders...
http://powerstrokearmy.com/forums/showthread.php?t=47492Is there any way possible to run a non Vgt AND be emissions legal? I need to return to stock yearly for emissions. Would that be too big a pain with tuning or possible at all? Ultimate goal is to stay stock fuel with a more reliable turbo. Not having any issues currently, just don't want to buy one turbo and wished I went the other another route.
Keith
Keith
Personally I want to be in the 600-650 range with the ability to tow my horse trailer and be a dd. I think a 66 and dual fuelers tunned moderately when get me what I want.
I will also go 3.73 and 33" tires to keep the drive train happy.
hmm right now I have 3.31 so I would hate to jump 3.55 and wish I had more. I would like to be able to use 6th gear.I had 3.55's and 35's lock 6th out and you'll be right at 2000@ 75. Right in the 66's wheel house. Carried 10 psi at 75 with a small load behind it.
in 6th your around 1700rpm?
I drive at 65-70mph due to the goat trail roads. speed limit is only 60.
yeah I am currently running matts tunning. the tranny is work sooo nice. better than stock imo.I used 6th gear as long as I wasn't towing more than 5k. And matts tuning made it way nicer to drive.
