twins with stock tranny?!?!
NORCAL6.0
stockton
cant find any other threads for what im trying to build....if there is please send me the link...
im doing a twin kit with a 62/70 and a S474, 190's for sticks, AD165, and tunes...(who ever's).... all of this with a stock tranny, just upgrade the clutch pack and the valve body. the truck is a daily driver that tows on occasion
any thoughts would be great! thanks
strokin6L
Springville NY
sure it'll hold...but dont expect to run a tune any higher than a tow tune cause it'll start slippin bad with anything higher than that. I remember Shawn installing twins on his dually with running the stock trans and it didn't like it too much.
RedSmokey
Sacramento, CA
Your ganna throw twins on but not a trans? How ass backwards are you Matt? LOL
NORCAL6.0
stockton
so would i have to do a full build on the tranny to run the higher tunes or are there some other things/ways i can work around it....reasons is i have warranty tell 200,000 miles... trying to keep the tranny cheap so if it goes, i dont have to much into it;)
RedSmokey
Sacramento, CA
You dont think they will pop the hood and see twins on the motor, then void the warranty? Or you have some hook up? :naughty:
Pizza pig
MD
Clutches and valve body? since when did a 5r get a valve body? By clutches do you mean you have new clutches in the trans? Need a little more explanation to this
The stock trans should last a little while if you have it tuned conservatively, Matt moroni ran his like that for a little while until it blew itself up LOL
NORCAL6.0
stockton
yes matt and i have been on the phone talking about this a lot lately.... on your second question.... just getting aftermarket parts for the tranny....without buying a full billet
Pizza pig
MD
A modded direct solenoid and new clutches (with more clutches than stock) will work just fine, add in a converter later down the road? Thats what I did and so far so good.
NORCAL6.0
stockton
ok thanks.... well know when its put together and it holds or not....what do you think on the fuel of the build?
windrunner408
190s will be plenty especially if used with 100% nozzles. More than enough to burn the tranny up.
motoxracer42
Trans didnt blow itself up lol. i burned the direct clutches racing in redding while spraying the crap out of it (Ellertons Idea lol). Matt you will be fine as long as you are tuned correctly. If you decide you want to add the direct solenoid you need to tell your tuner. You will be looking for a tow truck if not lol. You can also mod the pump and run two solenoids if you run billet shafts. 190s will barely be enough fuel. it will clean up completely.
Pizza pig
MD
whats the difference? LOL Like Matt stated, tuning is key.
