Vacuum pump constantly running
D66stroke
Baltimore, MD
I haven't hooked a gauge to test for leaks yet, but I did plug the red line running to the ESOF solenoid since that's a common route for leaks. I also used my fingers to plug every open inlet/outlet on the pump itself and it still wouldn't shut off. Is it possible the pump could be bad if it doesn't shut off?
