Valve cover gaskets
Nic
Santa Fe, Texas
When replacing the valve cover gasket, what else has to be replaced with it? Any injector O-rings or tubes too?
Mesa, AZ
Injector o rings, and the ford kit will come with the jumper tubes, injector to valve cover seals are a good idea, depending on which side you’re doing, ccv box o rings or egr seals, the upper intake will have to come off, so intake gaskets as well. If your egr is on it, drain both cooling systems.
Nic
Santa Fe, Texas
Thank you sir!
