Very heavy ROMP
DEEZUZ
NO PUKESTERS
NWI
Excursion. Pcm had 8 volts for vref and 8 volts for module supply. Installed new pcm. Vref now 5 and module volt is battery. Great.
It still romps. 11% to 33% constantly. All other 5v sensors are great.
New ipr new icp sensor new pigtails. Tried cam sensor tried idm. Nothing. It just romps and then if you hold it at part or wot and let it idle down it dies. Fires right back up.
psduser1
on the road
What oil? Miles since oil change?
Sounds silly, but it really might be that simple, I've fought that myself on my ex.
DEEZUZ
NO PUKESTERS
NWI
Looks oem.
I did top off with 4 quarts today. I was Gunna change oil in the AM but I am running super short on time and needed some more suggestions. Thanks.
fastersteve
Have you checked the alternator? Should be 14+ V running. I've seen bizarre behavior with low voltage. Seems like alts only last a few years on mine.
tomlin
Athens, Illinois
I second the alternator suggestion. Even with it charging at 14v it can be defective. Alternators produce 3 phase electricity. It is rectified to DC through diodes. If a diode fails, you start to get more of the AC waveform. The electronics don't care for AC and it will cause all kinds of weird issues. A good shop with a good scope or scan tool can look for AC ripple.
ghohouston
Lewisville,Texas
I had a crazy ass issue that I chased forever. Truck would buck real bad, kind of felt like a miss, sometimes at idle and while driving Ended up being the female pins in the cps pigtail had spread out due to the wire harness clip not being present.
co04cobra
WV
Adding 4qts of oil would lean me towards injector orings or injectors themselves. Any back history previous repairs? Did you confirm the hpop is not aftermarket?
DEEZUZ
NO PUKESTERS
NWI
Changed oil. It legit idles 10x better. Ipr% only romps from 11-16% but still dies on decel. Will check on pump tomorrow.
All voltages are great, did not check for ac leakage though
