VGT Solenoid Connector
superduty4x4
Newport, WA
I broke one of the locking tabs off the VGT connector this weekend, looking to change over from the style with the 2 plastic tabs to the wire bail style connector. Does anyone know if you can or how to remove the wires from the connector so that I can just replace the connector itself and not have to cut/splice wiring?
Strokersace
Towanda, KS
In all seriousness, the pins are held in via clips on the plastic. Should be able to use a pick or something to unclip them and pull them out the back.
superduty4x4
Newport, WA
I was messing with an old 7.3 injector harness I have, and it looks to me like I'd have to release a retaining tab, slide the pin out the front, bend 2 little ears down, then pull it out the back. I'm just nervous to try and pull that off without f*cking up the pin so I was hoping someone else had tried it and had some pointers.
