Video of my higher RPM miss
Magnum PD
VA
Have not tried to unplug it yet.
It’s gotten worse as time goes on.
Magnum PD
VA
Done forgot where I got it. Think it’s a dual release valve. I think the chip cancels the fooler.
Hope it’s not a an IDM problem.
ghohouston
Lewisville,Texas
I had my cps pigtail connector pins get spread out due to not re installing the clamps for the harness along the front cover. Took me a while to get it figured out. My truck had a violent hiccup, seemed like a miss at higher rpm's. Sometimes wouldn't even start. Pushed the pin connectors back together, and have not had an issue since.
m_j
what boost were you at when it chatters? it sounds like mine when it hit the 35psi liimit of the OBS MAP
Magnum PD
VA
It will miss at all different boost numbers.
I did take the pigtail out and look at it. Nothing really jumped out at me. I didn’t notice any misses when I drove it this evening. I should have another CPS somewhere. They are from Ford.
