VIOLENT STEERING WHEEL CANT HOLD IT
mrjoe31mrjoe31
I have an 03 PS Diesel it has a lift...I put a new box/ steering in it 6 months ago
Then a pump a month ago and all he'll broke loose.
I've replaces the lines/ hydro boost pump twice....bled it every way possible and it is 100% messed up. I'm trying to attach a vid....I've been told everything its not so far.
Um I'm steering towards a bad valve in the box or hydro boost.
So all you super duty 6.0 fans
......verdict plea$e
Sent from my LG-H700 using Tapatalk
mrjoe31mrjoe31
Here is the short vid
Zzz %:!/÷*#.?!!!!!!!!!!!!
DEEZUZ
NO PUKESTERS
NWI
.... Post a pic of the front end, correct drop arm on box? What about track bar?
powerlifter405
Butt Town
Ball joints bad?
Wheel bearing bad?
Bad joints on the track bar?
Alignment issue?
track bar too short / out of alignment?
Steering linkage worn out?
Poorly balanced tires?
There could be a variety of sources. Inspect your whole front end.
Good luck, steering issues can be a nightmare to solve.
