webb06 official build thread
webb06
Seneca, MO
Why not just tie into the downpipe the way that kit was meant? Not being a smart a ss. Just curious
That was my plan. But it won't work. It seems that the single setup sits further back and there isn't room for the pipe after the gate it hits about where the downpipe vband is.
webb06
Seneca, MO
Got the wastegate done today. I know the discharge pipe isn't pretty but it should do the job.
webb06
Seneca, MO
Last nights progress. Took off the overload springs and the lowest spring. Installed the traction bar mount. Need to drill the frame for the front mount. Then they're checked off the list.
webb06
Seneca, MO
Talk about bringing this back from the dead.
So the truck actually runs and drives now. About the only thing left to do is get the exhaust routed into a stack and get the tuning refined.
Also considering gutting the bed and hanging the bedsides on some tubing like most other drag trucks have been doing lately.
I'll try to get some pictures uploaded soon.
Black AOD
Ohio
Things have changed quite a bit since then.
Yeah my bad Dylan....
I forgot you sold the black truck and it had bigger injectors in it after you lost your front pump....
So the new RC truck still has the built motor, Morgans front mount twin pumps, the 125% and the Big FI S476 correct ? With the built 5R ?
webb06
Seneca, MO
Basic recap of what's on the single cab truck
-engine out of the black crew cab(built with stock rods)
-trans out of the black crew cab (built but missing a few billet parts) we'll see how long it holds up
-Dual fuelers sitting up front on a mount that Morgan made for his pull truck
-125% rcd injectors
-76mm forced induction turbo
-fuel cell leading to an a1000 pump
-MPD remote oil cooler plate and turbo pedistal
Black AOD
Ohio
I honestly never knew anyone else other than morgan had that twin front mount k16 pump kit. Pretty cool to see someone else using it. Eliminating the valley pump location has got to make it way easier to swap those out if need be!
that is the actual mount off morgans pull truck..
