littleredstroker
where the antelope play
Swapped blown motor with a forged rod motor, got it runing Sunday, 15psiboost with old stock turbo that's rubbin the housings. Swapped turbos last night with TN . 15psi... No drive pressure leaks, no smoke, no heat. Matt says boost leak . Checked boots when swapped turbo and all are good . So I guess I'm building a leak detector today
sent while staring at a windowed block
THETANK01
Riffraff order showed up
weazel
Elkview WV
Pulled the EGR butterfly in the intake, and fixed my inner fender on my drivers side dually flare
Sent from in a ditch up side down and on fire with the wheels still spinning
bboteler
Virginia
Line-x
Here are the before and after...got the line-x done.
Turned out pretty good I think.
TXGLASSMAN
Keller Texas
Picked up a top side creeper for mine yesterday, just got done half as washing it, gonna go do my Sunday thing and come home and detail it this evening
Jomax
Arizona
Changed the alternator in front of an autozone driving to CA. Lucky I caught it in time.
Extended Power
Painted the grill last night.
Made custom air deflectors in behind the grill so all the air that passes through the grill will go through the intercooler instead of around it. (Had the "Zoodad" mod done on both sides for the air filter when it was a single...and a twin...but now it gets it's air from in front of the front wheel/fender.)
Removed all stickers from the back window.
Gonna drop the rear hitch, and do an oil change for something to do this afternoon.
Extended Power
Pulled the traction bars off and reprinted them Arizona Beige. (They were satin black before.)
Also pulled the overhead console display out to see if I could fix it....boy did I ever...
Ended up ordering a new one from a Ford dealer in Texas. (Local Stealership wanted $380.00 for just the display module...said I could have it for $300.00.....I said "no thanks."
