What turbo upgrade, stock fuel and trans.
Faster
I made a thread in tech, but didnt realize this section was here. I need new turbos and am looking to upgrade from stock but not looking to do a full build or risk blowing anything up. So far I like the BD Screamer. Any advice would be appreciated.
2008 F250
S&B intake
AFE 4" straight pipe
SCT Livewire w Rudy tunes
any make of 59mm high pressure paired with a 71 or 72mm atmo charger will max out stock fuel. mid 600s hp
Faster
Are they relatively safe to run on the stock engine? I heard you can run the same tuning without issue as well, is that true?
They are extremely safe. Tuning has to be modified for any high pressure turbo changes.
Sent from my SM-G955W using Tapatalk
Knich356
Richton,MS
What Size Would Be Worth The Money
Turbo Swap
My question is. I want to swap to a single turbo set up, but I'm needing advice on which set up would match my drivetrain and accessories upgrades? I don't tow I would daily drive 150-200 miles per day
I'm leaning towards a S366 which adds little HP & Less torque. I'm wanting to add EZ Lynk Tunes with the setup. Please Help
Swapped Rear Differential 3:73 to 4:10 Upgraded Two Piece Driveshaft w/ Thicker Frame for Saddle ppBearing, ATS 5R110W Stage 2 Upgrade, 8" Pro Comp Stg.2 Lift, 38/13.50/20 M/T w/ 20x12 -44 offset Wheels, Fully ******d w/ Computer 150hp Tune. 4" Straight Exhaust, Factory Up-Pipes, S&B Cold Air Intake, Factory Head Studs.p
10-30-2014 04:02 PM
