Hit the main menue key, top left. Then select "set defuels". Set your pyrometer 1 at 1450 degrees. Set boost pressure at, ooh, say 40 psi. Cold coolant temp at 180 degrees. Hot coolant at like 220 degrees. There's a start.. Obviously you can run more boost, hotter EGTs and so on so forth but it won't live as long..
I think it's hit or miss honestly. My job 1, I ran it on the hd300 tune daily till I sold it at 150k miles. Never had any issues, I did have the weekly light to light wot runs and hammering it on the on ramps to the highways. She was good to me, factory head bolts, no mods besides cai exhaust egr and dpf deletes
once my truck is warmed i get on it daily, not wide open necessarily but peg the factory boost gauge every day, once its up to operating temps.
my Job 2 service truck has been running his race tune for a good 30-40k... prior to that it ran HD300 for 50k. truck weighs 10,000lbs
my Job 1 I noticed a little tear-dropping as somebody so eloquently put it... But the truck had never been run hard. Might just be the coolant level finding its happy spot. Same thing happened on my service truck after we did thermostats on it. Once it found its happy level in the jug, it hasn't tear-dropped since. We'll see LOL
bottom line is life's too short not to run Matt's race tune!![]()
There are no job 1 2010's. job 1's are early 08's. all 2010 are job 3's. they is no difference in the bolts. But iirc there was another layer added to the gasket for the job 2 run.
08 Job 1?
My job 1 popped the gaskets the first time I punched it on a large file. Lol
The way I hear it, a lot of early job 1s had 6.0 gaskets. That could explain why a lot of them pop right away.. My Buddy blew his right away with HD 300 where my job 2 held Gearhead till I did studs and never blew.
Are the holes in 6.0 gaskets even big enough for 6.4 headbolts/studs?
6.0 gaskets?
Dam Kyle, you've had some crazy luck with that pickup.
No doubt, since I've bought her I've blown head gaskets twice, cracked the heads, torn the center out of my flex plate, lost the stock low pressure turbo, replaced weak LPFP, cracked a piston, and now a trans.
Funny thing is I drive the thing like a gramps most of its life. Getting rather expensive...
