psduser1
I had a local machine shop go it. If my lathe was big enough, I'd have done it in the shop.
A slight interference fit and some locktite to hold the bushing in the flywheel, and 2 to 3 thou running clearance to the input shaft bearing surface, machined after the bushing is pressed into the flywheel.
