1000 RWHP Build for the summer
ingrahams
New Hampshire/Africa
Craig@MFI
I exploded mine threw the front cover on kong with the ati dampner but never had a issue with stock sent the ati back since there are right up the street from us and they said it needed to be rebuilt after only like 30 passes
Sent from my SAMSUNG-SM-N900A using Tapatalk
Athens, IL
you've seen one break? ive never heard or seen it until mine.
A handful. Wes beech, Craig and a few others.
I can't say it is and rpm issue, I've never had that problem.
I just wonder if it's an alignment issue. I have had them "click" when building an engine, then loosen it back up, turn the crank a few and tighten slowly and the click went away. Since there are no dowels in the front cover I can see this happening. A always install, rotate and then tighten so that way it kind of finds it's center.
Yeah, they say your supposed to freshen every season. But that's just them covering their a**. If the damper is truly bad it could ruin the pump. But the whole thing would vibrate and idle rough etc. it would be noticeable. Seems like it's just a freak thing that only happens once in a while. Seems that they are always after an engine has been put together too. I have not seen a factory installed one bust yet.
But it's not a common enough problem for anyone to get too worked up about. Unless your one of the unlucky ones.
ingrahams
Well The truck ran flawlessly for the past 3 weeks, I did have a new exhaust pipe between the turbos made because the one I made was leaking. Still screwing around with my trans tuning trying to get that dialed in. Was rained out the day I wanted to get to the track do that will have to wait till spring.
Also replaced the OBS with a 6.7, loving this truck
-Stew
MaxdLaw
Granite City IL
You should make some more videos of driving and acceleration and what not when you actually have some time off!
