Before........and...........After....
TRUBBS
Balls Deep
so ill bite....
where is it coming from?
Look at the inside of the intake....it's full of soot....any guesses as to where its coming from?
Hint: it's not from the primary sucking in exhaust...
Extended Power
Drive pressure over 100 psi, boost only 65-70psi...both intake and exhaust valves open for a split portion of a second...exhaust flows out into the intake...
Now we all know why keeping back pressure in check is important. (Read "back pressure" gauge.) lol
Extended Power
I bet. Who did the intake mani?
It's a GoGo manifold.
I did the porting, and came up with the idea of changing the intake on it.
I had an old intake manifold I cut up first, to see if it was even do-able.
Bought all the pipe and fittings, but had a shop weld up the aluminum elbows and vbands on the intercooler and intake manifold for me. (Im a bad enough welder on mild steel, let alone try mig'n aluminum without a spool gun.)
I did the rest of the mig'n myself.
Extended Power
Starting a collection.
Now...if these are here...what's in the turbos now?:naughty:
It's gonna be phuckin nasty!
I hope.LOL
Extended Power
It's official.
You change your setup more than I change my underwear. :morons:
You said that last time...or maybe it was Snake...:D
It's a hobby...addiction, or disease.....I'm not sure...could be all three rolled into one.
Only thing I wanna do yet, is get a hood, and paint it...that will be the end of the really expensive stuff.
Might be time to move on to something else.
Extended Power
I guess this would be as good of place as any to mount the controller...
(It's just hanging there, I just wanted to see what it would look like.)
Here is the bracket I'm gonna use with it. I will have to drill into the dash to use more than just the sticky pad to hold it there on hot days. (Look close, and you will see that I drilled and tapped the mounting plate, and used 3 small screws to hold it to the mounting plate.)
Yes, I will trim the screws off after...:rolleyes:
Extended Power
Found a set of KR bucket seats to put in the rear, and get rid of the bench. (Wanna see the amp rack on the back wall.)
Only picture I have of them, as they are sitting at the border...ready for me to pick them up on my days off.
