zilla68
I bought this for the 99-03 7.3's knowing it might take a little work to fit on the obs.
It was pretty simple actually, the kit is very nice and came with everything you need. I had to redrill 2 holes on the plate that mounts to the doghouse and trim off the excess. By drilling 2 holes in line with the 2 predrilled holes it moved the mounting plate closer to the doghouse.
The reason I drilled the 2 new holes is to keep the CCV filter from hitting the brake booster.
I then trimmed the excess between the 2 new holes and the original holes.
Then I had to bend it a little in a vise to get it positioned correctly since the 2 newly drilled holes put it at a slight angle.
The CCV filter is adjustable and I didn't realize it until after I had drilled the holes, it might have worked by just turning the filter more towards the front of the truck.
the catch can bolted right to the frame, right where it said it would.
Took me a couple hours, pretty simple, pretty easy.
I got it from strictly diesel.
I'll get a pic of it installed and upload tomorrow.
