Block Modifications?
Viking
Minnesota
Has there been blown motors with girdles due to not enough reinforcement? I'd assume at some point the bolts will hold all the forc in concentrated ares instead of dispersing it throughout the block.
I have been wondering if there were a way to weld something the the bottom of the block instead of bolt to increase the strength on the whole block itself.
Hotrodtractor
Mingo, Ohio
There is fretting occurring on the mains even with a girdle - it occurs less with some block filler.
Viking
Minnesota
I had a conversation with Lott about this, and I believe he has a solution for that. You might want to call and ask him about his girdle. He doesn't advertise it, but it's a nice piece.
So all is well? I must call and chat then, I don't want to do any filler in my block.
Big Bore
9000ft in the CO Rockies
I can't say it eliminates the need for filler, nor would I think it does really, however it addresses the mains walking better than the other girdles IMO without the cost of having to go to a full bedplate.
JDub
Hooper, Utah
We prefer to do all the cryogenics work before any other work is done, hence our name 'CryoFirst'.
powerstrokenstang
Verona VA
my block filler has cracks in it, is that normal? you can def get fretting w/ a girdle and block filler, mines doing it pretty good.
TARM
I need to look up the name on the filler I was specifically reccomended - but I was told that its expansion rate was nearly identical to that of cast iron - since I trusted the source I never bothered to confirm.
I have mixed experiences with sleeving engines - I can't say that I would go out and sleeve a perfectly good block with the intentions that it will be stronger - but I am also not opposed to the process for bore repair as well as taking care of any coolant cavitation that might have taken place.
Thanks.
If you are willing can you post the name of the polymer filler or send it to me in a PM I would greatly appreciate it.
I am back forth on the sleeving, wish the info could be more definitive. My thought to the positive is it would prevent undetected pin holing from wasting the build on a block.
907DAVE
AK
Just fill it!!
With my block filled to ~1.75 from the deck I can barely get my oil temps over 200 when towing heavy (14k), and normal driving stays around 185ish.....and that's using the 203 T-stat.
Magnum PD
VA
Just fill it!!
With Hardbloc? How hard is it to fill? Machine shop has to do it?
907DAVE
AK
I used the Moroso brand block filler. Not hard to fill, just be sure to have a helper when doing it, you need to move at a steady pace before it starts to set. After I smoked a piston (20k later) the filler still looked the same as when I filled it, no cracks, chips, etc. Also, there was no flaking....... the oil cooler was spotless.
