Arisley
Berman, first, make sentences, it is really hard to read.
Second, swap the suspected bad injector with another one. See if the issue follows the injector or stays with the same cylinder. If it follows the injector, problem solved, bad injector. If not, you have some more troubleshooting to do.
Remember to evacuate the cylinders before installing injectors. If you don't, you problems could multiply X10.
