First time out of the garage in three years.
Needed a bath!
One day I will find the time to finish this project.
Tapatalking from a wind turbine
ya know, sometimes you just have to take time off and do it..
KBMKVIII
Very true.
I'm off till the 13th so hopefully I can make some head way.
Motor out, new oil pan gasket, may try some beehives, and just got the injectors back from FF, D60 swap, put in my '10 center console and '06 seats in... The list goes on... But all that can wait today. Heading to the lake!
Very true.
right on man!
JrStroker
Ahead of the competition
wow. tight fit!!
Very tight, but Corb made it work.
What happened?
Dsberman nailed it.
He needs a hpfp on it.
Dam right!
Yep and took out the whole fuel system. I think he's going to do a build on it now.
Sent from my SCH-R970 using Tapatalk
Yea, gonna try and do a small build. 75% injectors and 76/62 highpowers.
€ory Anderson
AlaskanTrucker379
Sterling/Soldotna Alaska
Got my projectors finished. Just need to hook up the halos still. They are hidden under the shrounds.
Low beam
High Beam
All my wiring for the high beam dimmer and halos. Its quality that makes a difference. Heatshrink, and expanded sleeving
Sealeveloc
Berlin MD
I installed all new rotors and pads on friday, rear passenger side caliper is locked up, great........ advanced here I come.......
KBMKVIII
Prepped and ready to pull for next time I come home on R&R.
Oil pan gasket and dipstick pipe, oil cooler, redo the hpop lines, fuel lines, new water pump, checking the front cover, lpop, possibly headers, massage the firewall, new redhead steering box oh yeah and put my D60 under it lol
I'm sure I will end up doing quite a bit more like rail plugs and the whole 9 yards while I'm in there.
What color should I paint it?
Strokersace
Towanda, KS
Ford blue for paint
In a black truck? Yes it's better than a red pickup but no.
But then again, if he used the metric Ford blue paint, it may be cheaper than the inches Ford blue, huh?
My vote would be gunmetal gray or something with silver, polished accents.
