03 hpop install
swinky
Eastern, Nc
Putting a hpop in my 03 tomorrow. Seems pretty straight forward. I know I have to pull the intake mani bacause I have that crossover in the back. Before I tear into it I want to make sure I don't need any special tools. Also going to do a delta line while it's apart, anybody know what size freeze plug the front cover takes so i can get rid of my welded E G R cooler?
Thanks guys.
HOOV3R
Central PA
thanks man. then I can just leave the welded E G R off of it and leave two holes open or do those need to be plugged?
You'll need to install a delta line for oil cooler coolant return. Will still need blockoff plates for the air side.
swinky
Eastern, Nc
well **** I figured I should've ordered one of those. I guess I can probably just cut off the little j tube and use the E G R as a "block off plate"
Living at an appt sucks, I really don't get to work on this thing and learn as much as I want to.
ghohouston
Lewisville,Texas
Total length is 11.5 inches, and measurement from cut end to bend is 8 inches. I wouldn't go any shorter, because I've had some ipr's that were insanely overtightened, and we're hard to break loose with this wrench and a hammer.
swinky
Eastern, Nc
lol this is tarting to sound inapropriate. I'll be yanking the turbo so I'm not sure if I'll need to bend it.
ghohouston
Lewisville,Texas
I was waiting for you to say that. I mean I can get mirror pics, sideways, undershots, whatever lmao.
Anyways it all depends on ipr position. I assume you've never pulled one. You will see what I'm talking about, or may get lucky. I assume you have access to a torch if you do need to bend it? I've never tried it with a straight wrench. I got mine from someone else.
swinky
Eastern, Nc
Yeah I'm on the boat right now. Gonna borrow all sorts of stuff so I don't get stuck in the middle of the job.
Sent from my HTC One M9 using Tapatalk
03cody
Bethany Illinois
I pulled my Ipr with a straight wrench. Its not too bad, just have to work at positioning the wrench some. once its broke loose you can undo it by hand.
