Cam Swap on stock 6.0L....
78f100
Bonifay FL
Looking forward to the results, I know it will be legit results with Zeb doing the testing. He is a stand up honest guy.
fordboy11
Conneaut Lake, PA
I wish we could do a cam just back to back. But we have a cam from Straub that I just put in the truck this week with a 62Non vgt and full fuel system with 190/75. should hit the rollers next week. See how she goes.
Straubtech
To be clear on this. Before:
Stock 6.0L
Stock Turbo
Stock Injectors
Stock Camshaft
White Rain Extreme street
4 Pull from 309HP to 330HP, average was 320HP
On Friday it will be dyno'd as the following:
Stock 6.0L
Stock Turbo
Stock Injectors
Straub Camshaft
White Rain Extreme Street
Same Dyno Same Operator.
Then it will dyno'd with:
175 Stock Nozzles
Stock Turbo
Jessie Warrens Tuning
Straubtech
Nice. Will be good to see some final numbers. You know you're doing something right when all people do is line up to piss in your cornflakes. Cheers!
Ahhh, its all part of it. After 28 years of being in this industry I have some thick skin. I have all to prove and I understand that.
Super Diesel
Middle Georgia
Stock 6.0L
Stock Turbo
Stock Injectors
Stock Camshaft
Stock 6.0L
Stock Turbo
Stock Injectors
Straub Camshaft
175 Stock Nozzles
Stock Turbo
Interesting...
Straubtech
Well what do you think?
Dieselmore
Apache Junction Arizona
Stock 6.0L
Stock Turbo
Stock Injectors
Stock Camshaft
Stock 6.0L
Stock Turbo
Stock Injectors
Straub Camshaft
175 Stock Nozzles
Stock Turbo
Thanks for the clarification.
Are you going to be able to overlay the before and after dyno graphs?
fordboy11
Conneaut Lake, PA
Andy and jesse had it up on the dyno last night and the numbers I was told was 556hp an 115X I didn't get to drive it on the street. it also had more in it but jesse had to pull PW back as it started dropping ICP. This is also on a ZF6 truck.
strokin6L
Springville NY
It started dropping ICP with 190/75's? 190's should hold ICP without any issues. How healthy is the hpop?
Straubtech
By giving the engine what it wants when it wants will make for much more efficient engine. This will in turn make the engine want more.
fordboy11
Conneaut Lake, PA
The pump had almost 200k on it.
You just described most of the women through my life!
That is all my women. :fustrate:
Andy did say he likes Straub cam better than others. So im sure this wont be the last one we install. Im sure my pulling truck will find one and the shop truck as well.
strokin6L
Springville NY
But has Andy or Jesse tried the new RCD cams? I'd like them to try one and see how much difference there will be from the Straub if any!
SICKS LITER
Salem, NH
Stock 6.0L
Stock Turbo
Stock Injectors
Stock Camshaft
Stock 6.0L
Stock Turbo
Stock Injectors
Straub Camshaft
175 Stock Nozzles
Stock Turbo
309-330 with an xtreme street tune? that sounds way off.
