OBS no start
Winchester, VA/ Bloomery, WV
Bumping this back up again. Truck is at Twisted. They found 2 bad injectors, swapped them out, but now it sounds like it's got low compression. Truck is still running poorly, and looks like it's time for a refresh. Is he better off rebuilding the motor in his truck, or finding a good shape used motor and putting it in. His budget is fairly tight, so that plays a part in it as well.
Bugman
Gypsum, Co
Without doing a compression test you won't really know what is going on with the engine.
If he is on a low budget he would be better off finding a used engine instead of going the rebuild route especially if he isn't doing the work himself.
