Precision 6466 Versus 6870
50_shooter
Central IL
If Firepunks dyno is that accurate I could have been in the top 10 lol
I don't know where I ended up, but I was in the top 10 for most of the day, was 10th place around 4pm. And that's with several of the higher horse pulls being nitrous hits. (They didn't separate the fuel only from nitrous numbers).
jcain
Maybe it was on a different tune/setup than what made 12xx fuel only or 1600 on the squeeze...
Six_Sloww
Southeast MI
What 6.7 are you guys talking about? I guess I hadn't heard about the 1200 horse 6.7 fuel only...
Tyler@sdp red crew cab truck has been putting the hurt on some little dynos lately.
I'm not trying to take anything away from it, he's gone 10's in that 8000+lb truck with a 6r140 which is one of the most impressive things I've seen this year Imo.
It's just funny how things go once Facebook gets ahold of it, because now a s476 is good for 1600hp, and you're an idiot if you say otherwise.
50_shooter
Central IL
I see. I figured it was some shop's truck. Even mid 900's is pretty good on a 6.7 for fuel only from what I've seen. Very few out there.
Administrator
Mid 900s. 12xx/19xx on the bottle
which is EXACTLY where that turbo should be on fuel . all of us with similar turbo's are in the 950 range. its not rocket science, and it certainly isnt 1200 . my 75 has done 905 , 928, and 959 ... ive always figured it a 950 hp setup .
osiris
Would this turbo be alright towing or is it too big? I just picked up a 2016 and have been reading and reading about everything haha
Six_Sloww
Southeast MI
How much do you tow? Riding in Pete's truck there's no doubt you could tow with it, just depends on how often and how heavy.
osiris
Right now not much maybe 8k. Might upgrade the camper at some point tho so maybe 12-15k but it still would only be a few times throughout the year.
50_shooter
Central IL
I tow with mine a lot. Nothing real heavy, probably 12k is the most. I just turn it all the way down with my mini max so it doesn't fuel as hard. I wouldn't say it's ideal, but as long as you keep it in a low enough gear it works great.
jcain
That's counter productive.
Fuel it normal down low and limit it up top.
Sent from my SM-G930P using Tapatalk
bpan
So your running the barder on stock internals? What is the plan with the truck?
