CCLB Traction Bar Install Questions
I drill frames all the time and if you go get bits at fastenal a cordless Milwaukee will penetrate the frame in seconds.
8WR_ZJ
I use a step bit plugged into my 1/4 hex drive impact. Unreal how fast you can drill a 1 inch hole in a frame or anything. Plus with the impact feature of the gun you don't even have to push hard it does all the work for you.
dsberman94
Pennsylvania
Good trick. Are you talking about a screw impact gun or an automotive grade impact?
8WR_ZJ
Its just an 18v dewalt one. I think its really called an impact driver. I like it because its really short and light and can get in some awkward places.
That what I used, along with Milwaukee drill bits, their most expensive ones.
UNBROKEN
That's what I was thinking. I used good bits and a cordless 1/2" drill and it was nothing to drill the frame. Started at 3/16" and worked my way up.
Kxc
South Jersey
Great thread, definitely will be referencing this. Just ordered a set today from Midwest , shout out to Jared for all the help!
I get the 19/64 all the time for drilling out aluminum topside rivets and i know for a facti can shove it through a truck frame in about 7 or 8 seconds in a 18v cordless milwaukee drill. I wont ever use cheap tools again. Life is just too short lol.
Im not sure the brand but i can check. They are unreal bits. I picked up 20 of the 19/64 last week and it was close to 500 bucks. But if you had ten holes to drill in a frame one bit would get it and be worth the 22 bucks.
I was trying to drill a steel handrail with "some real good Deeeewalt golds" last week. This older guy says dewalt weird and he thinks those 20 piece bit sets are high quality. Anyway, i melted his 5/16 in about ten seconds. Puahed hard and it cut briefly and then you could just feel it die. Melted. LOL I told him "get your junk off my job". LOL
Kxc
South Jersey
A high quality cobalt bit is the only way to go. Nothing at a big box store will last
Heres the efffin muthaeffas that i use. I buy 1/8 and 5/8 from them too.
WHY NOT
Carlyle IL
I got a bunch of fastneal drill bits that are dull as hell. When they are new they cut like crazy though.
Kxc
South Jersey
Did you guys upgrade your U-bolts to 3/4" ? Or are they larger on the 350 and 450s? Getting ready to put the bars on and I read where they recommend going with 3/4". My F250 seems to be 5/8"
WHY NOT
Carlyle IL
My bolts are flipped upright now with the adjustable top plate and traction block on the truck. I didn't just use the under mounts and went higher so I had to get new U bolts anyways. Just using the under mount system I'm not sure if you need new top plates or not. Good question for Jared.
