The Next Chapter
ChattyCathy
Umm...no. The turbo has two turbos. So, a three way, not Lucky Pierre.
Let me understand...You got the hen, the chicken, and the rooster. The rooster goes into the chicken so who is havin sex with the rooster?
JRLott
TX
Heck if I know. Just two stuffing into one, and I don't even wanna think about Pierre.
Montana Ford F350
Rexford Montana
making progress.
next will be lift , wheels and tires .
Does the tailgate panel simply unbolt ??
Does the Ford emblem on the front grille also just unbolt??
Thanks,
Montana Ford F350
Rexford Montana
Have you had any issues with the headlamps from retroshop? I had a set on my dodge and the right side would flicker between normal and dim all the time, was quite annoying.
not sure how if they flickered it would be their fault, considering the electronics in the lights are stock .
we got the intercooler for the 2017 test fitted , it requires a cold side pipe extension , which is included with the kit. ive immediately noticed .5+ mpg gain and significant throttle response and low end power. i'm very shocked at the performance increase so far.
