dcswetman
3 369sxe's right Mike?
Well now.... the turbos turbo, has a turbo!
Umm...no. The turbo has two turbos. So, a three way, not Lucky Pierre.
whats the hen doing?Let me understand...You got the hen, the chicken, and the rooster. The rooster goes into the chicken so who is havin sex with the rooster?
getting face ***ked.
making progress.
next will be lift , wheels and tires .
Have you had any issues with the headlamps from retroshop? I had a set on my dodge and the right side would flicker between normal and dim all the time, was quite annoying.
these where different set up then the ford. they added projectors to the factory set up where the fords are a lot nicer set up and a better light from the factory.not sure how if they flickered it would be their fault, considering the electronics in the lights are stock .
They should have a warranty on them, have you tried to contact them about some replacement parts?
yes, did not get very far.
