No ***kin ****. This is getting hilarious.
Stop mucking up this thread....
Who's tuning do you recommend?you should wait about 30 more days, also the kc38r and NEW kc69r will surprise you, charlie has already commented but i think everyone else is right, you have a issue you have not found. I have plenty of customers on kc38r with 160-238c/100% and no real issues and way stronger tuning then ********, Tuning is the key to any injector, id suggest other tuners.
it will be a upgraded drop in turbo to fill the void to go t4
Mikeegg02, your running 31's where as the op is running 35's. If he dropped tire size I bet he would see a big improvement. Rotating mass is a big power killer.
I'm in for results of the change or if you find something else causing the issue.
Always wondered if injectors from different builders would act with the same tuning. One being slower injection, faster, etc... causing issues like this, slow spooling high egt pig.
I'm putting a 38r in my obs cause from experience it's hard to beat. If your interested in selling yours pm me a price
Just look at that lonely old speed sensor port. When is someone going to spend the money for one? It would be nice to see where these things are hitting on the map.I guess I'm about to drink the coolaid too, and I can't wait!
Sent from my SM-G950U using Tapatalk
I'm working on getting the other part of the puzzle to get it mounted.Those look a lot nicer under hood Get her in there. Your permagrin will immediately be installed too. If you previously had a 38R, the most intriguing thing is realizing the turbo is coming up on boost, and you have to look at your gauge. Because you can't hear the first few psi like previously. Once you realize it's coming on quicker than normal, go for a few rips, you'll be pleasantly surprised.
I just want to get it in the truck, I didn't even think about a speed sensor.. googling now lolJust look at that lonely old speed sensor port. When is someone going to spend the money for one? It would be nice to see where these things are hitting on the map.
