6.0 fan on OBS Results....
Swaan
Not sure on mishimoto rad. They claim better cooling over stock blah blah blah.
I think your on the right track with the sd fan and van clutch.
I wish I knew about that mod back then..
Central CA Foothills
Back in the day when I could have cores built to order by Modine I would have used a pre 95 copper radiator and had a core built with a high fin per inch count, plate fins with louvers and a few other tricks I forgot.
Swaan
I looked at every availible fan horton makes for that bolt pattern. Nothing seems to fit perfect. Been there, done that.
Horton can recommend all they want but ultimately it's the hub position fore and aft that's going to dictate if it's going to fit. Not to mention diameter but that's a givin.
Peroni
North Carolina
Swaan did you find something that would fit the Horten clutch but would need modified? If there is something out there that has the right offset and diameter but the wrong bolt pattern or pilot diameter I can mill/drill/turn it to make it fit. Having to use that clunky stock fan has kept me from putting in a Horten clutch.
Swaan
I did.
I wish I can find where I got it made...
I will look again tonight.
Swaan
www.americancooling.com
These guys will custom make any fan you want. They also stock many types.
They changed there website since last time that's why it took me a while figure it out.
American cooling soloutions was the name.
You basiclly have to measure your hub back spacing you need , ccw or cw rotation and diameter. You can spec your blade pitch also and how many blades.. You go into prouduct search and then put in your specs. The fan I used was one they had in stock. They will build a custom fan too but you shouldn't have too.
I wish I had the part # I used would save you guys bunch time.
If I remember right it was a 23" 9 blade with 5" pilot on 6 bolt. Counter clock wise.
Peroni, there are some 4 bolt small pilot fans that could be modified as you describe, I've been trying to figure out how to hold center, and hold the fan by the steel while boring out the center of the steel.
gunnellett
Washington
I talked with a fellow today who took a slightly different route with this mod. He used the plastic 7.3 SD fan but coupled it with the fan clutch from the 7.3 SD van. He had a lot more radiator to fan clearance with his combo than I do with the 6.0 fan and OBS fan clutch. I wasn't able to get any pics as we were both filling up at the local gas station. Just another avenue to explore for others wanting a better fan setup.
I know this is an old post, but have other folks tried the van fan clutch with the 7.3 Super Duty fan on an OBS? I have a 96 in need of a new fan clutch and am looking at options. Thanks.
