New setup for the MPD Cabelas truck
Craig@MFI
Got the hd converter and new Trans and overdrive finally holds
Hits 79 psi with the converter locked now
Administrator
damn 80psi out of a single... crazy. sounds like you could use some headwork...
That's a ***ing insane amount of boost from a single turbo. That pressure ratio is 6.48... unreal what they are doing for the maps on that wheel
Sent from my DROIDX
Craig@MFI
Hooking backpressire guage now without dual fuelers I could see it with the factory guages now I can't with the dual fuelers
Craig@MFI
went to the local pepboys dyno yesterday and made 1088hp on .136 yet with fuel still left over
still running stock springs, stock pushrods, stock cam, stock heads, intake manifold, and just arps with the double bat 75 and bullseye 45mm wastegate, rudys dual fuelers and 100% nozzles
Craig@MFI
last pull the i believe the straps were loose because at the top of the power the back of the truck was hoping and shacking
CAT35niner
NJ
Damn Craig that is insane. Hopefully i can get my truck down there to be worked soon.
