got this in today.. now i need a 15 pump and turbo of some sort to utilize #5
8WR_ZJ
finally got around to getting my new to me, and the first set ever of, aftermarket rims i have ever owned(big thanks to jomax on the deal hea gave me!!) and new 295/70r18 mastercraft cxt's.(dam things are rated for 4080lbs each[emoji106][emoji106][emoji106]) also got the new x4 tuner with ghead sotf from mikey installed(minus the swicth for now)... ran out of time. need to get to bed. will have to do that tomorrow. just left it in the tow tune for now. a big thanks to bigrpowr for the tuner too!! cant wait to try the sotf when i get it installed..
After put a few more miles on them post up how you like or dislike them. I am looking at this exact tire. I tow my toyhauler and want more capacity my current tirest are only at 3700 lbs. I want the 4080 lbs capacity and the shortest tire possible.
they ride great. my brother has them on his f150 and his wifes yukon. i have put 3 sets on some of our work trucks here and the guys like them a lot. that is the only size that has that rating too.. the 295/70r18s i believe.
01pwrstkr
Polk County NC
Looks great!
Sent from my SM-N920R4 using Tapatalk
it does.. thanks again bud!! yeah no doubt.. i had you for a second though! i was literally laughing my ass off when i was typing what i said about the ziplock bags ripping and the lugnuts rolling around.. thanks man.. a bit wide for me but i like them.
Kinda reminds me of this...
put this on this morning. ordered it a couple weeks ago. been wanting it for a while. its a cheap rough country kit but better then nothing. as soon as the shocks show signs of leaking ill replace with bilstiens. the new rims and tires made bump steer way worse but this kit took it all away. basically got rid of all the bump steer there was..
04cr450
harford county, maryland
Looked at it... then brought home a 17 platinum to sleep on... looked at that as well... sent the 17 back.. i am a mess with these trucks... bored is what it is, may try a different brand now but definitely going to keep the 16 to modify etc etc.
slc6oh
Utah
changed the oil over to Jims LE 5w40.... for what its worth, it dosent tick like the fomoco 10w30 did at first....
You're bad lol, I'm in love with my 17 KR.
ckrueg
Belding MI
Decided to strip the clear on my wheels. Turned out good, even without really polishing them much. Surprisingly wasn't that bad with sprayable stripper and a power washer.
Glad to hear pal. Lets see if the new truck lasts like the old one. Your new truck looks awesome, like the two tone color combo.
Thanks bud! Need to make a proper daily driver "build" thread about it.
changed the fpcv to see if it would help out with my rail pressure drop in the hotest tune i have. and the slight drop i have in the performance tune but it was super clean. no shavings on it clogging it up.. guess i need a bigegr hpfp or my low pressure is sucky.. lol
dsmracing1
Alberta, Canada
My low pressure was sucky too lol. Not anymore with the H&S LPFP. The I only thing that kinda worries me is the exposed filter now possibly freezing on a cold day but I’ll soon find out!
LE 2411 full torque winter blend from jim. never be an issue then..
