eastern
How can I change factory settings like horn beeping when getting out of truck with key fob in pocket. Also want to have power to trailer plug all the time. Seems only works when truck is running. Thanks
If you want "HOT" to trailer with ignition OFF,you'll need to run a Wire from battery to Female plug on your truck,and connect to the corresponding post for interior trailer lights.Been there done that.Bad thing is,if you forget to turn off trailer lights,you'll have dead battery in am!How can I change factory settings like horn beeping when getting out of truck with key fob in pocket. Also want to have power to trailer plug all the time. Seems only works when truck is running. Thanks
