Upcoming Head Gasket replacement
Roccafellas
Same thing happened to me, if you haven’t already read “08 6.4 for $4000 please help”
Anyways same predicament same problems, just sharing my build and components I didn’t have a big budget but for the buck this was the best bang
http://store.dynamicdiesel60.com/mobile/64-power-stroke-2008-2010-stage-1-master-over-haul-kit
That kit is awesome man comes with EVERYTHING youll need.
the lifters.. upgraded with better retaining clips, stage 1 cam, pistons etc i couldnt be happier with it and its cheaper than any other kit or sourcing each part out yourself @Toren302 buys a lot from Paul at Dynamic and his youtube videos prove he’s no BS.
Arp studs
Chromoly pushrods
High rev valve spring
6.0 manis and up pipes
4” downpipe
5” exhaust
NO LIMIT Cold side pipe and intake
The kit and the rest of ^ cost maybe $4g canadian. If that. So pretty cheap for all new internals minus crank and rods
Reusing the injectors and hpfp because i don’t know if that was my problem but we planned to reassemble and test and replace as needed. My block was 10x worse than yours you got lucky, maybe you can get away with .20 over or so,
Strokersace
Towanda, KS
Arp studs
Chromoly pushrods
4” downpipe
5” exhaust
Looking at the erosion on that piston, I would not be reusing your injectors unless they are 100% gone through or completely replaced.
Roccafellas
The combination of too much fuel or too little air will have the same result – thermal growth or piston crown erosion. This can be attributed to clogged air intakes, restricted exhaust, malfunctioning turbo, incorrect fuel pump calibration, injector contamination, and of course, injection or engine timing.
I had a clogged intake and clogged cat. I had no prior issues of a bad or leaking injectors no smoke, no knock it ran perfect. Until I stepped on it, and it just choked and died.
kleake
Sapulpa, OK
I was looking at that same kit last night and thought it looked pretty good for the price. I already have new lifters, push rods, rockers, studs, exhaust, manifolds, up pipes, etc. Mostly just need bottom end stuff (bearings, pistons, rings, stage 1 cam, gaskets and some machine work. Gotta hunt down a competent machine shop around here next.
Arp studs
Chromoly pushrods
4” downpipe
5” exhaust
Strokersace
Towanda, KS
You're engine, your time, your money. Good luck.
Roccafellas
Give them a call still they can work with you and build you a custom kit Paul is awesome
Roccafellas
Hey I agree with what you’re saying the logic is good I just don’t have the funds right now to go ahead and do so so it’s going to sit until either decide to try it and test it and hope for the best or just go spend some money and get some new sticks
Strokersace
Towanda, KS
I would be very leary of anything from Paul at Dynamic Diesel. See the thread on here about all the issues people have with their work...
Roccafellas
Yeah I’ve read the stories. Everyones got issues. To each there own really.
To the OP
GOODLUCK!
kleake
Sapulpa, OK
On the way to the machine shop to see what all is needed.
Hole all the way through.
Everything out. The crank looks really good, but i'll have it polished anyway.
On the trailer ready for the machine shop.
Roccafellas
i was referring to dynamic .
Hey man I had a somewhat bad experience too, everyones human, sucks to see this many people with bad reviews, but he treated me fair, my engines not together yet and running so no i dont know if his parts are built to spec or well for that matter but so far the machine shop and i have no issues. Sorry for other peoples losses.
kleake
Sapulpa, OK
Long story short, my block was too far gone. Bought a used motor in hopes of a usable block, but it was worse than mine. Found a good block from another forum member and had it shipped here. Machine shop took forever, but finally got to it. .020 over pistons and stage 1 cam showed up today and will be taken to the machine shop tomorrow. I hope they are faster at this last part so I can get it back. I've been down since october...
Sent from my SM-G950U using Tapatalk
kleake
Sapulpa, OK
Picked up the block Friday and spent the weekend assembling. Didn't get the rear seal from the dealer and ran short on lube for the studs so I didn't get it back on the chassis yet, but it's close. Sure feels good to finally be going back together.
Shafer171
Michigan
Looking good. Glad to see I'm not the only one using a 2x to help my engine stand. Those Damn thing are heavy aren't they!
