The Next Chapter
C2tuck
North Texas
Yeah but you two still have diesel running through your veins...
At least bigr still has two diesels to offset the F-150..
Rub it in. Lol.
WhiteMamba_Scorpion
Butthurt?
Over paying 20k less for an F150? There's just dunes and trails everywhere on my daily commute damn it I should have bought that rolling house payment... what was I thinking? LOL eat a Snickers
Sent from my Galaxy S7
Black AOD
Ohio
My comment wasn't directed toward you about him having an F150 raptor. It was a general statement
Go play in your concrete [emoji14]
WhiteMamba_Scorpion
Brazilian Steak House. Pencil me in.
Now back to nut swinging on Mike LOL
actual update-
got the fleece cheetah in last weekend , its much stronger in the mid range and a good bit stronger up top. i was shocked at how limiting the stock charger was, boost went from 48psi and 69psi of back pressure to 58psi of boost and 66 psi of back pressure. the ebp sensor did $hit the bed so i need to replace and confirm , but that should be correct with the larger turbine of the fleece. next will be some 45% injectors from dynomite just to max out the exergy 10mm pump . still on stock motor , all is well, today LOL
Staying tuned for the firework show!
mine has updated rods , and has had it's ass kicked at 50psi with fuel , i think if it was gonna fail it would have already, as the others have failed quick. if it does, i have a motor ready, but would prefer not to turn mine into an anchor .
gotchadollar
I think it will be an awesome test to see if it will last. Does make things a lot easier to swap when you don’t scatter the block! Good luck dude!
50_shooter
Central IL
By updated you mean stock rods on all 17-18's right? Or have you had this motor apart?
qzillanut
Of course it’s stock 17-18. He even said so. It’s just that they got better rods for the 17-18 and someone has to be brave enough to find the limit of them. Honestly I’m not gonna push mine to the edge. But I appreciate what mike is doing. Without testing we have no knowledge.
Black AOD
Ohio
For reference
2011-2016 style rods on the left, 2017+ Updated Rods on the right
FYI Some 2017 trucks did not get these rods. Most did but some did not. Star Off road found out the hard way with their F450 and so have a few others
Danny26
Idaho
FYI Some 2017 trucks did not get these rods. Most did but some did not. Star Off road found out the hard way with their F450 and so have a few others[/QUOTE]
Anyway of finding out if you have them? Other than the hard way.
