mcdaniel1991
Help ![](//emoji.tapatalk-cdn.com/emoji144.png)
******d, 169xxx miles.
Truck makes visible white smoke at idle in the mornings. I suspect it is still doing it once warm but it’s not noticeable. Exhaust smells terrible. I suspect ither leaking injectors or turbo seal.
-Ebp,map and baro all check out.
-Power balance showes no issues.
-No bubbles in fuel bowl.
During the KOER test it smokes a good amout (
test was performed at 120* because the symptoms disappear At operating temp) the smokes subsides substantively when the test finishes.
Video attached of power balance and koer test.
Anything else I can check before I start replacing chit.
![](http://emoji.tapatalk-cdn.com/emoji144.png)
