Laxman1306
- Joined
- Dec 29, 2019
- Messages
- 18
- Reaction score
- 0
So just got done installing my new motor and was hoping the boost issue I had the last time I started the truck before I tore it down was something wrong with the motor but It’s still not building boost. I did put a scanner on it and got code p2262 and p2263 which is a turbo performance failure... I did try another MAP sensor and it made no difference and the EBP sensor is working fine... I split the turbos and replace the gaskets between them and the seals that go through the elbow and small pipe under the fuel cooler.... the turbos seemed fine and spun freely and had now slop to them but I’m wondering if there is something wrong with the secondary precision turbo set up I have on it... any help with this issue would be great.
This is the set up I have.
